change a row text colour when a cell = value x
Princy557
Post by Princy557 »
Hi,
I would like to make a row (5 columns) to change to text color light gray. the action to be triggered by the 5 column value.
I already have col2 and col3 triggering the col5 to show as 'COMPLETE'. From that saying complete I also want the row-col1 to 5 to all change to light gray text?
How do I set that up, please?
Regards
Princy557
Regards
Princy557
Re: change a row text colour when a cell = value x
Please share the file and the condition for which you want to implement this action.
ananclipping
Post by ananclipping »
Princy557 wrote: Fri Dec 13, 2024 8:36 pm Hi,
Regards
Princy557
You can achieve this by using conditional formatting or custom scripts. For example, if you're using a framework like HTML and JavaScript, you can add a condition to check the value of col5. If it equals "COMPLETE," apply a CSS class to change the text color to light gray. Here’s a simple example:
javascript
Copy code
if (col5 === 'COMPLETE') {
document.querySelectorAll('.row').forEach(cell => {
cell.style.color = 'lightgray';
This should change the text color for all columns in the row when col5 displays "COMPLETE."
Princy557
Post by Princy557 »
Sorry for my absence, Christmas, New Year and family have been a priority.
Seasons greetings to you all.
I need another two days to get back on track with this problem.
Note: After Supertech asked I uploaded a small file, which I can't see on this forum. I'll re-upload soon.
Regards
Princy557
Regards
Princy557
