Morph transition?
Re: Morph transition?
Thank you for your post. I have forwarded this improvement suggestion.
The morph transition is not natively available in many presentation apps like PowerPoint or Google Slides, but in apps like Microsoft PowerPoint, it can be implemented as a "Morph" transition feature that animates objects smoothly from one slide to another. Check if your app has a similar feature or use creative animations to mimic this effect!
