How exactly does RoundUp work?
NX-01
Post by NX-01 »
I have a cell whose function is W30/200 and the result is 5.25. But I want that result rounded up to 6. However, if I enter the roundup following the example in th program
Code: Select all
=RoundUp(W30/200 [, 1])
it returns an error and instead of a number, it displays other things.
So, how do I make freeoffice round the number up to 6?
stascheit
Re: How exactly does RoundUp work?
Post by stascheit »
Use this formula syntax instead:
Code: Select all
=RoundUp(W30/200, 1)
Return to “FreeOffice PlanMaker 2024 for Linux”
