ChatGPT Feedback and Feature-Suggestion
Brachialberzerker
Post by Brachialberzerker »
Hi there,
I've tried out the ChatGPT integration in TextMaker 2024 NX, and I was surprised by how bare-bones and ultimately useless it currently is. The integration uses the GPT-4o-mini version, which has very limited capabilities and does not perform well on complex topics—at least not as well as the larger models. This is somewhat expected given the smaller model's limitations.
While this integration is a unique NX feature (likely due to commercial considerations), it is simply not worth using in its current state, particularly for serious workloads.
However, if it were possible to use my own API key (acknowledging the privacy implications), the feature would offer much greater flexibility and usability. Additionally, having options to select text and apply helpful commands such as "add details," "add sources," or "expand topic" would significantly enhance its usefulness. The ability to configure and provide basic context data to GPT on demand would further improve the experience.
In its current form, the integration feels underdeveloped. I understand that SoftMaker likely incurs API access costs and relies on subscriptions to offset these expenses. However, this could be addressed by allowing users to optionally enter their own API key. This minimal adjustment would greatly enhance the feature and make it viable for inclusion in the buy-once version as well.
Regards,
BB
Re: ChatGPT Feedback and Feature-Suggestion
Thank you for your post. I have forwarded this improvement suggestion…
m3city
Post by m3city »
I would like to respond to that subject.
I feel kinda cheated on, because information about ChatGPT and integration of deepl is either misleading or missing. I specifically upgraded from v2021 to 2024 standard because of those two. And found out that it is not included. Is that infomation clearly shown on softmaker page or not? Have I missed it somehow?
The feature lists/charts are clear that Chat GPT and DeepL are only included with NX, the subscription version.
Neither of which is enough to induce me to rent software.
