Cell Format Character
louyo
Post by louyo »
I want to put 1-4 in a cell. When I enter it and select character or Ctrl-2, it still enters it as a date. I also tried highlighting the whole column and tried setting it for character.
I updated to latest today. Not sure if it has always done this. I am running in Debian 12.5. Hopefully, it is short circuit between the headphones.
louyo
Re: Cell Format Character
Post by louyo »
Just ran it in Excel and formatted the columns.
I'm not sure what you mean when you say you "select character or Ctrl-2, it still enters it as a date." I just tested it in PlanMaker for Windows and it works properly. The way it works is that BEFORE entering data, highlight the cells you want to enter that data style in, right click on any of the highlighted cells, and select "Cell." From the pop-up, select Number Format and set it to 'Text."
You need to press Ctrl+1 to change the cell formatting. Ctrl+2 just pulls up the dialog box for character formatting.
You can also put single quote (') before 1-4 and then PlanMaker will not convert '1-4 to date.
Return to “PlanMaker NX and 2024 for Linux”
