FlexiPDF 2025 for Windows does not print correctly
allen@amulvey.com
Post by allen@amulvey.com »
Attempts to print from FlexyPDF 2025 print about one inch at the top of each page all else is blank. Adobe Acrobat prints the files correctly.
My system:
Windows 11 Pro 64-bit
64 GB RAM
NVIDIA GeForce RTX 3060 Graphic card with current drivers
Xerox WorkCentre 6655i
Any help would be appreciated.
Re: FlexiPDF 2025 for Windows does not print correctly
Thank you for posting your problem. Please share the file with which you are getting this issue.
