A duplicated button in rev.2025.404.1112
Ar-Paramir
Post by Ar-Paramir »
Hi, I've updated to the latest revision and found that in the status bar the brand new "Fit Two Pages" button has the same icon as the "Fit Width" button.
In the main ribbon it is OK:
But in the status bar it's not correct, it looks like there are two "Fit Width" buttons, only by hovering/clicking you can understand which one is where:
Please fix it in the next revision.
Re: A duplicated button in rev.2025.404.1112
Thank you for reporting this issue. I have forwarded the details.
