Font rendering on Wayland
Post here topics for SoftMaker Office NX and 2024 for Linux that do not fit in any of the application-specific subforums.
smcstewart
Post by smcstewart »
I've got a niggle with font rendering in Wayland running on ZorinOS. I've attached a screenshot of the basic system below.
Fonts for all Office NX apps, fonts are blurry, which is similar to what I've found with Electron apps (screenshot at the bottom). The workaround for Electron apps is to add in the options to the desktop file the following:
Code: Select all
--enable-ozone --enable-features=UseOzonePlatform --ozone-platform-hint=auto
, which I did for PlanMaker, but it made no difference.
I've also tried testing with both the "DPI" and "Smooth edges of screen fonts", but neither makes any discernible difference.
Just wondering if anyone else has come across something similar and perhaps how they resolved it.
lgsl
Re: Font rendering on Wayland
Post by lgsl »
smcstewart wrote: Sat Nov 16, 2024 8:58 pm
Code: Select all
This will never work because is only applicable for Electron.
Go to Settings => Appearance and set "Smooth edges of screen fonts" to Subpixel.
If this do not work then:
1. The way ZorinOS is rendering fonts isn't optimal. Hence why you also experience this with Electron Apps. (This is quite probable)
2. You set GNOME to scale and it is forcing to scale SMO somehow and creating such distortions. If so try turning off the scaling.
3. Because of the nature of Wayland and how many things are implemented trying running SMO in xorg/x11 instead may also do the trick.
smcstewart
Thanks for that. You're spot on - it's Fractional Scaling. As soon as I have it turned on, blurry, even at a whole percentage. Turn Fractional Scaling off, and everything is AOK. Just need to suck it until Fractional Scaling is working better on Linux.
Appreciate the insight, thanks.
sergiuvolda
Post by sergiuvolda »
Have you enabled fractional scaling? This feature is known to cause X11 apps to appear blurry in Wayland.
Fedora Linux Workstation 42
Former Manjaro and Ubuntu user.
Return to “SoftMaker Office NX and 2024 for Linux (General)”
