delete/remove frame
delete/remove frame
How do you delete/remove a text frame from softmaker 2024 document?
Re: delete/remove frame
Just right click on its edge and select Delete, or click on the edge and hit delete key.
When I do that, everything is deleted, text and frame. I just want the frame deleted.
If it is a text frame, the text is part of the frame. You should copy the text first and paste it again after deleting the frame.
- Contact:
Are you just looking for removing the border around the text frame?
Then you should first determine if there is really a border. If it is a thin gray line, it just shows the dimensions of the text frame and does not print. Else, right-click on the frame border, open the properties and remove the border.
