Autofit cell size to contents in Planmaker
Panch
Post by Panch »
I am new to Softmaker Freeoffice Planmaker, and I cannot so far find any command to autofit selected cell sizes to their current cell contents. Is this feature just missing in Freeoffice but found in the paid version? Do I search the Softmaker Planmaker 2024 manual for some term that means the same as "autofit"? This function is quite accessible in Excel, but maybe Freeoffice chose otherwise? I especially value autofit column width in Excel.
Re: Autofit cell size to contents in Planmaker
Layout > Cells > Optimum Width + Optimum Height
This doesn't pre-set columns to automatically resize as you enter data, but it will resize to fit the cell contents. You can also double-click the column header and the column will size itself to fit the longest entry.
Return to “FreeOffice PlanMaker 2024 for Windows”
