How to export .pdf to .jpg 1:1
Is it possible to export a pdf file as a jpg file 1:1 ? New .jpg to look exactly like .pdf.
Re: How to export .pdf to .jpg 1:1
File > Export > Pages as...
Click "Format", go to tab "General", uncheck "Text Output" and check "Image Output". Choose "JPEG" as format from the dropdown menu. Tab "Image" gives some additional options like resolution and image size.
Click "OK", choose the page range and click "OK" again.
Thank you, Jossi, but do you try this ?
After doing many tests with different settings, I realized that: if the file contains only text, only the "Text output" option should be selected, if it contains text and images, both options should be checked - "Text output" and "image output" . In the first case /text only/ the file cannot be saved as an image. In the second case, the program creates different files for the text and pictures. In practice, there is no export of the entire file in one picture.
That's what I found when I experimented with it.
My best suggestion is to use the Windows Snipping Tool app.
- Contact:
On the General tab, uncheck text output and check image output, then you get JPEGs of the full pages.
That’s what I wrote. And if the PDF has an image layer and an invisible text layer, both cannot be exported to a single JPEG file because JPEG (as an image format) cannot store text.
- Contact:
Yes, I was just repeating this as the original poster seemed to be confused.
I forgot one point: in the "General" tab, the option "Convert each page into an image“ must be checked. Otherwise, the image files contained in the PDF will be stored separately.
This is the key. Thank you.
