Arabic BiDi RTL support
aazzoma
Post by aazzoma »
Hello Dev Team
kindly add
1- BiDi support to FlexiPDF, the current editing tools are missing BiDi
2- mirror / flip horizontal the objects and elements of the whole page
3- add DeepL API key
4- LLM GPT API integration API Key with prompts to customize the translation domain and accuracy
Ref:
https://www.iceni.com/help/Infix/7/en/B ... cHebr.html
https://www.iceni.com/bidi.htm
Horizontal Flip - Text
When automatic-flip is enabled, text columns, titles, captions etc. are all flipped to ensure a more natural reading order for the target language.
Horizontal Flip - Images
During automatic-flip, images are moved on the page to reflect the change in reading direction but their content is not affected.
Horizontal Flip - Vector Artwork
Vector-based artwork is mirrored when the automatic page-flip is enabled. In many cases this will work fine but in some cases it may be innapropriate. For those PDFs you can disable the auto-flip feature.
Re: Arabic BiDi RTL support
Thank you for posting your suggestions.
aazzoma wrote: Sat Oct 26, 2024 10:08 am 1- BiDi support to FlexiPDF, the current editing tools are missing BiDi
I have forwarded these improvement suggestions.
aazzoma wrote: Sat Oct 26, 2024 10:08 am 3- add DeepL API key
DeepL Write does not offer an API that can be controlled, but is only a web app.
aazzoma wrote: Sat Oct 26, 2024 10:08 am 4- LLM GPT API integration API Key with prompts to customize the translation domain and accuracy
I have forwarded this improvement suggestion…
