Word docx opened by Textmaker does not wrap at margins
Panch
Post by Panch »
I opened a Word document in Textmaker and saved it in docx. This document has word wrap at margins in Word, but the now Textmaker version has lines that go all the way to the right edge of the Window. I previously unchecked wrap at window edge. Suggestions on how I can get Textmaker to correctly display the originally Word document, i.e. with lines wrapping at the document right margin, not at the window edge?
Re: Word docx opened by Textmaker does not wrap at margins
How and where did you uncheck wrap at window edge? I've never seen anywhere to check or uncheck that. TextMaker defaults to wrapping at the right margin, not at the page edge or the window edge. It's no different when importing files in the .docx format. Is the text just text on a page, or is it text in a text box or in a table?
Can you upload a copy of the file?
Panch
Post by Panch »
Thanks. My confusion. I was/am new to Textmaker and was opening previous Word docs with bulleted lists, which I never seem to figure out. Withdraw the question as formulated.
Return to “FreeOffice TextMaker 2024 for Windows”
