missing subscript and superscript
agar
Post by agar »
Hi
I'm a new user, so excuse if I'm missing something. I want to be able to format characters into sub/superscript and I can't find any way of doing it. I looked at the user manual and these buttons should appear next to font colour and other character format options (strikethrough) but on my toolbar they aren't there. I can't find them through 'add buttons' either. The command group "character" doesn't look like depicted in the manual. Shortcut keys don't work without the rhs numberpad on my laptop.
What else can I do to access these?
Aga
Re: missing subscript and superscript
Thank you for your post. I have forwarded the details.
Meanwhile, if you want you can use ribbon interface which have these buttons.
Return to “FreeOffice TextMaker 2024 for Windows”
