Bug report Quick Access Toolbar
Kinggeorgia
Post by Kinggeorgia »
If I add a Custom button to the quick access toolbar, the next time I launch FlexiPdf, it will crash on startup. The solution I found was to use Revo uninstaller to make sure all registry entries where removed. After reinstalling all would work as it should. I have tested adding of a button to the QAToolbar again and it results in the same crash. I exported the original registry keys before adding a button. If I deleted the registry keys that have the extra button and import the original Flexipdf works again. I did not check to see if the theme was part of the crash. I am using the dark theme.
Hope that helps.
-KG
Re: Bug report Quick Access Toolbar
Thank you for your post, but I am unable to reproduce this crash. I have tried multiple commands in quick access toolbar in dark mode.
Is there any specific command/ button which making this crash?
Kinggeorgia
I will take a look to tomorrow.
Kinggeorgia
Try to add the Hide and Show All buttons from Text Box. Those crash every time for me.
Thank you! I was able to reproduce the issue and have forwarded the details further.
Return to “FlexiPDF 2022”
