no decimals in csv export
robert006
Post by robert006 »
With the latest update, a csv export does not export the decimals in numbers.
Planmaker 2024 S1218.0824 Windows 10
robert006
Re: no decimals in csv export
Post by robert006 »
The decimals are exported when exporting with the default additional options csv export, but not when just .csv export is chosen.
Thank you for your post, but as you mentioned it's working?
Please share complete details of the problem (if any) with sample file and steps involved.
robert006
Post by robert006 »
Thank you for your help. The problem must have been with the file that I was exporting to csv. When I create numbers manually and export as csv it works fine.
