"Disk full or inaccessible" error message
Suengoo
Post by Suengoo »
I have the same issue trying to save a plan maker file.
MacBook 2024. Sonoma doesn’t matter if I change the file name, the disk drive etc. still says disk full or inaccessible.
Re: "Disk full or inaccessible" error message
Please open settings> Click on “Privacy and security” > Files and folders > PlanMaker, please give full access to PlanMaker app so that it can write data on your folders.
Please try the above step and share the feedback.
Please post your query/problem in the relevant forum only. As your issue is with PlanMaker for Mac and not for “TextMaker 2021 for Android”, I have moved your post here.
WhyMe?
Post by WhyMe? »
This solution didn't work for me, in the sense that I had already given MacBook system permission for SoftMaker/ PlanMaker to access my document folders, so that clearly isn't the thing causing the issue.
Furthermore, it wouldn't be the best solution given any system changes only take effect after a SoftMaker restart, and that would mean you lost all the work on your unsavable document.
Any other solutions out there? There is, of course, selecting "save as" and then changing the file name slightly, which does seem to work, but it's less than idea when this happens to a file randomnly and you have to go through the rigmarole of it all when there's pleny of space left on your computer...
Thank you for trying. Please reinstall SoftMaker Office and then check again.
Return to “PlanMaker 2021 for Mac”
