can not import some front that chinese work musted use
qjqiang1
Post by qjqiang1 »
like 方正仿宋、华文小标宋。which is must used in the goverment working type . hope you can fix it thank you
Re: can not import some front that chinese work musted use
Please share complete details of the problem with the sample document, steps involved and screenshot of the problem for better understanding.
Return to “TextMaker NX for Android”
