Missing column in Planmaker
Tardis40
Post by Tardis40 »
At some point the the past I created a worksheet by copying and pasting data from another worksheet. I have formulas tied to the new worksheet and everything is working fine. When I recently looked at the columns and their data I noticed that Column A is not shown and it starts with Column B. I thought A was hidden but no matter what I try I can't show a column A in that worksheet. I assume that the worksheet doesn't start with column B and A is hidden somehow.
Any suggestions on how to fix this?
Re: Missing column in Planmaker
If column A is hidden, you should see a small triangle at the top left corner of column B. Simply click on that triangle, and column A will become visible.
Alternatively, you can select column B, then press and hold the left mouse button while dragging it to the left as if you're selecting column A as well. After that, right-click and choose the 'Show' option.
For a visual guide, please refer to this screen recording, which explains both methods.
Tardis40
Reveal hidden column
Post by Tardis40 »
I have a worksheet that starts with column B and haven't been able to find a way to reveal column A. I've tried a number of steps from he help file but have been unsuccessful. Anyone know how to show a hidden column?
Tardis40
Post by Tardis40 »
Thank you. Second option worked great.
Re: Reveal hidden column
Tardis40 wrote: Sun Oct 13, 2024 6:48 pm Thank you. Second option worked great.
But here you mentioned that the second option worked for you.
Tardis40
Post by Tardis40 »
Sorry about the duplicate post. I'd forgotten I'd already asked and someone answered but didn't see the notification until after I clicked Submit.
I didn't think too much about second post because when I clicked on Submit nothing seemed to happened so thought something went wrong and just closed my browser. Obviously it did post.
I have fixed it now by merging both posts. :)
Return to “PlanMaker NX and 2024 for Mac”
