No Document Map in Sidebar
Brian I
Post by Brian I »
Hi,
My sidebar is missing functions - it only allows me to show SoftMaker info, paragraph styles, and character styles. There is no document map or page thumbnail or other options. They are not available for activation under the View>Sidebars menu either - only the three I mentioned are. Can someone please tell me how to activate the document map function.
lgsl
Re: No Document Map in Sidebar
Post by lgsl »
Are you using SoftMaker Office, or FreeOffice?
If you are using FreeOffice then you must remember that is not a full-featured office, but a limited one. Also keep in mind that changes where made to the lastest version of FreeOffice and some features where removed. Probably this is your case (also meaning you posted this in the wrong place :wink: ).
In case you are using SoftMaker Office, then make sure you are not hiding any of the sidebars. The document map tab can be moved from one sidebar to the other, but can not be disabled.
