Shortcuts for text styles
Giovanni_Becattini
Post by Giovanni_Becattini »
Is it possible to create shortcuts for my own paragraph styles as I do in Word?
I tried to find an answer but I couldn't.
stascheit
Re: Shortcuts for text styles
Post by stascheit »
Right click in the text, choose Paragraph style from the context menu.
A dialog box will be opened. Select the desired style on the left list and click on the Edit button.
Another dialog box will be opened. Click on the last tab Style.
-> Here you can enter the Shortcut key for this style.
You will also see, that for some of the predefined styles shortcuts are already assigned. For example:
"Normal" style: Alt+0
Heading1: Alt+1
Heading2: Alt+2
etc
Giovanni_Becattini
Thanks, I couldn't find it!
Return to “TextMaker NX and 2024 for Mac”
