TextMaker does not display images in the index file
MerlinNeedsHelp
Post by MerlinNeedsHelp »
When I open a file with several images it USED to show an icon of the image and the name it was saved as. I just added 32GB of memory and it no longer shows the icon of the image. Just a place holder and the name it was saved under. How can I get the image icon back? Using Windows 11 and TextMaker 2021.
All help is appreciated.
Re: TextMaker does not display images in the index file
Thank you for posting your problem. It seems that adding additional storage somehow changed the path of saved image files because of which you are getting this problem.
Please check and see, where images were stored before and now. Restore the path and the issue will be fixed on next reopen of the file.
