how do I select a textbox
merlizbet
Post by merlizbet »
Hello,
I've created a textbox in my PDF. Now I want to move it to another location. Coming from Adobe Acrobat, to select the textbox I would just hover/click any non-resizing spot on the textbox bounding line and it would allow me to drag the textbox somewhere else. Using FlexiPDF2022, I can't figure out how to select the textbox, so I can't move it *or* delete it.
Any help with this problem would be most appreciated!
Re: how do I select a textbox
Thank you for posting your query. To move a textbox, please select object tool, drag and drop the textbox on desired location.
Please see the below screen recording for your reference:
merlizbet
Post by merlizbet »
Thanks!
Return to “FlexiPDF 2022”
