An option to switch sheet direction from right to left
fadi
Post by fadi »
Free office 2021 had this option in sheet properties but not in 2024. Also I would love to see an option to render numbers in eastern arabic numerals
٠, ١, ٢, ٣, ٤, ٥, ٦, ٧, ٨, ٩.
Re: An option to switch sheet direction from right to left
Please click on ribbon command File | Options | General tab | Check the option “Extended support for Arabic text” and after that you will get this option in Worksheet properties.
fadi
Post by fadi »
Thanks a lot. But how about rendering numbers in eastern arabic numerals. Why don't add an option in the future for that, say under language tab ?
I have forwarded this improvement suggestion.
fadi
Post by fadi »
When the user switches sheet direction to right-to-left, the direction of the horizontal scroll should change as well , it does not and the result is weird reverse scrolling .
raitis.veksejs
Post by raitis.veksejs »
What do you mean by horizontal scroll direction? If you are talking about worksheet horizontal scrollbar, input direction in cell has no relation to worksheet scrolling direction. Can you provide example how do you see this feature or how should it work?
fadi
Post by fadi »
The issue I am reporting is very important for right to left support. This is the right direction for the horizontal scroll bar :
right direction.png (2.77 KiB) Viewed 201554 times
This is the wrong direction:
Libreoffice does not have this problem
Thank you for sharing screenshots. I have forwarded this improvement suggestion.
fadi
Post by fadi »
I posted these issues a long time ago and there was hardly any modification. I live in the middle east and I need these features:
1- the direction of the scroll bar should change with the change of the sheet direction to right to left.
2- the default text direction for all the cells in the sheet should change when I change the sheet direction as well.
3-If possible, the ability to render numbers in eastern arabic numerals.
I have again forwarded these improvement suggestions.
fadi
Post by fadi »
fadi wrote: Tue Dec 17, 2024 8:36 pm
Features 1 and 2 are actually bugfixes . Without them right to left is useless . I understand feature 3 may take some time . There is no way I could replace ms office in the workplace without these features. If I had posted this issue in the non free section would it get more attention. Anyway , in the middle east, rich gulf nations may benefit from these features as well. I would love to know when would I expect these improvements ? [-o<
Thank you for your patience. I’ll be sure to share any updates from our team here as soon as I will get any news.
At this time, I’m unable to provide specific details about timelines or revisions.
Return to “FreeOffice PlanMaker 2024 for Linux”
