White squares instead of logos
Léon
Post by Léon »
Yesterday I started using SoftMaker FreeOffice 2024.
Minor inconveniences: 2021 was still there (not overwritten). All the settings, chosen fonts and dictionaries were no longer there. And so on.
I like the new logos (icons?,thumbnails?) for PlanMaker and TextMaker less than the previous ones, but here it comes: they are gone. Blank squares on the Taskbar.
Re-attaching, restarting computer: it doesn't help.
Please see the image.
Léon
Re: White squares instead of logos
Post by Léon »
Special trick:
First, I attached both programmes to the Start Menu and removed them from the Taskbar.
Then right-click both logos in the Start Menu>More>attach to the Taskbar.
Successful!
So from the program folder in Program Files (x86) it doesn't work properly.
