0xc000007b error
billc
0xc000007b error
Post by billc »
I am suddenly getting a 0xc000007b error on Flexipdf 2022. I have reinstalled the .310 version and restarted a few times. Also tried to run under Administrator with no luck. Also reinstalled the Visual c++ redistributables as suggested on a Microsoft site.
Softmaker Office runs fine.
Re: 0xc000007b error
Thank you for reporting this problem with the troubleshooting steps you performed.
As you have already reinstalled FlexiPDF, this problem seems on operating system level. You may try these steps:
1. Please update your windows and then restart.
2. You can also try the following commands after step 1 in command prompt as administrator to repair corrupted system files:
Code: Select all
DISM.exe /Online /Cleanup-image /Restorehealth
Code: Select all
sfc /scannow
billc
Post by billc »
Tried the suggestions and it still doesn't work. FlexiPDF seems to be the only thing affected.
billc
Post by billc »
It's working now. Apparently the c++ redistributable that I downloaded from Microsoft was not the latest. CCleaner updated it to a newer version and that fixed it.
Return to “FlexiPDF 2022”
