sum whithin one cell
phil29
Post by phil29 »
Hello,
I need to sum multiple numbers in one column .
It seems only one number at the top of cell can be sum.
SUM(ABOVE) or SUM(#B2;#B2) same problem
Please help a newbie
Re: sum whithin one cell
Tables in TextMaker work just like a spreadsheet. You can only enter one numerical value in a cell, and then enter the SUM formula in another cell.
You will have to split your invoice "Item" and "Cost" cells into multiple rows, with one row for each item and its associated value.
phil29
Post by phil29 »
Thanks a lot for explanation !
It works in microsoft word.
Maybe a future update ...
I have forwarded this improvement suggestion.
