Becomes Defaut
johndimmock
Becomes Defaut
Post by johndimmock »
Hi, I have installed FlexiPDF 2022 but not as default I still use Acrobat for reading and FlexiPDF for editing.
If i open a PDF from clicking PDF file icon which is the Acrobat icon it will open in Acrobat, If I open the same file in FlexiPDF is will open in FlexiPDF but the next time I click on the Acrobat file icon if will open in FlexiPDF, I have use right click open with Acrobat by default it works until I open it in FlexiPDF and It happens again until I do the right click Open with again, I have even set it in the setting section of windows 10 and the same thin happens. between this and the shutdown issues it is completely unusable.
Re: Becomes Defaut
Thank you for the post, but I am unable to reproduce this problem also. Please completely reinstall FlexiPDF and then check both the issues after system restart.
johndimmock
Re: Becomes Defaut
Have downloaded again and re-installed and re-started computer and it is still the same
Re: Becomes Defaut
Thank you for trying. Does that happen when you open a file directly from the desktop or from somewhere else also?
johndimmock
Re: Becomes Defaut
Hi, It can happen from any folder, It seems worse now I can't set it from "default application by file extension" I tried to set default to Acrobat and it just keeps FexiPDF as default but I can do it by right click and open with. At the moment I can live with this it's the shutdown problem that concerns me more.
Thanks for your help.
Re: Becomes Defaut
Please check your private message inbox and let us know the result.
Return to “FlexiPDF 2022”
