How to add FlexiPDF to outlook
lupor
Post by lupor »
Hello guy's
I'm a newber here anda I need to add a suplement of FlexiPDF in outlook. How can I do that?
Thank's a lot
Re: How to add FlexiPDF to outlook
I don't understand what you are asking, and I use both Outlook and FlexiPDF.
lupor
Post by lupor »
Hi,
When I'm using a message with a PDF attached in outlook, how can i put FlexiPDF us a default viewer?
It's my question.
Thank's a lot
lupor wrote: Tue Jul 02, 2024 7:10 pm Hi,
It's my question.
Thank's a lot
Isn't that handled by Windows?
Settings > Apps > Default Apps > Choose default apps by file type
Scroll down to .pdf in the left column, then clock on the name of the app in the right column and select FlexiPDF
Return to “FlexiPDF 2022”
