Replacing Home with Universal
Perrorist
Post by Perrorist »
I have Home installed, but would like to replace it with Universal. Do I need to remove it from my PC before installing Universal?
Re: Replacing Home with Universal
No, reinstallation is not required, just convert your product key with NX Universal using any of these special offers.
Perrorist
Post by Perrorist »
The product key I received is identical to the Home version!
In case you think I tried the Home version:
Yes, product key will be the same as you have successfully upgraded your subscription.
Please click on ? (right top corner) > About, if it's not already NX universal, please click on Manage license option and reactivate your product with the same product key.
Perrorist
Post by Perrorist »
Thanks. That worked. I am impressed with the customer support 've received so far.
