Fill blank cells with 0
musicnerd1984
Post by musicnerd1984 »
Hi, everyone.
I am using planmaker as an excel substitute to prepare a large dataset for an analysis on JASP. I have thousands of columns that are comprised of cells that are either blank or 1 (1 if a person has checked an option in a survey). I need blank cells to be 0 so JASP can calculate frequency for either value.
I have tried the "find all and replace" approach by leaving the find value blank and replace value 0. Planmaker returns an error for this, because it wants a value in the search box. I have also tried a spacebar input for the search which also returns the same error.
My next attempt at a solution was to create an IF formula at the top of a column IF(A2=1,1,0). This did return 0s, but did so for EVERY cell, including the 1s.
Can anyone provide a solution? I don't want to have to purchase excel just to fill blanks with 0s.
Re: Fill blank cells with 0
Thank you for your post, but this feature is not available, and I have forwarded this as an improvement suggestion.
Meanwhile, as a workaround, you can use this formula =IF(A2=1,1,0) and then replace the cells as values.
I have attached the sample file with this workaround implemented.
Blank to zero sample file.pmdx
(7.47 KiB) Downloaded 4275 times
Return to “PlanMaker 2021 for Mac”
