How do I select a printer in PlanMaker?
CountMountjoy
Post by CountMountjoy »
In TextMaker when I print a document it asks me to pick the printer. In PlanMaker when I press Ctrl+P or File→Print it tries to go to what it thinks is the default printer which does not exist.
How can I get PlanMaker to let me pick the printer?
(PlanMaker 2024 (rev S1210.0217) 64bit TextMaker 2024 (rev S1210.0217) 64bit Windows 11
Re: How do I select a printer in PlanMaker?
Interesting. I just checked, and this is a problem. There's more:
I have a printer connected to my computer and always on. TextMaker prints to that printer with no issues. PlanMaker won't print to it. It recognizes that there is a default printer, but it reports that [default printer name] is off-line ... which it is not. I just tried PlanMaker from FreeOffice 2021, which I have on a thumb drive, and that works as expected -- when the "Print" window opens, it provides a drop-down menu from which to delect the printer.
CountMountjoy
Thank you, This seems like a pretty serious problem and I will report it to SoftMaker. I found a work around. I go to File-> Export as pdf Then I open that file in Adobe Acrobat and send it to the printer of my choice.
AHA! When I got the "Printer is off line" popup I was clicking Cancel. I chose Ignore instead and then I got the popup that lets me choose a printer. The next time I tried to print a spreadsheet I got the normal "choose your printer" popup.
CountMountjoy wrote: Sun May 05, 2024 9:39 pm AHA! When I got the "Printer is off line" popup I was clicking Cancel. I chose Ignore instead and then I got the popup that lets me choose a printer. The next time I tried to print a spreadsheet I got the normal "choose your printer" popup.
Interesting. I would not have thought of that, but that worked for me, too.
frankbuk
Post by frankbuk »
Thanks for this guys. It solved the issue for me. Not fixed yet in the product?
It looks like everything is fixed now. However, are you experiencing any issues after clicking the cancel button?
Feba98
Post by Feba98 »
Hello guys....
To select a printer in PlanMaker, go to File > Print, then choose your desired printer from the list of available printers in the print dialog box.
