Slide size changing
vladimir1993
Slide size changing
Post by vladimir1993 »
Can anyone tell me is it possible to change a size of slide in SoftMaker Presentations for android OS, for example for creating a poster?
Re: Slide size changing
Thank you for your post. Ideally, if you want to design a poster, the best application is TextMaker NX for Android for you.
In Presentations, to change slide size please follow Changing the slide size and orientation section of our user manual which is applicable in our Android app also.
Return to “Presentations NX for Android”
