worksheet register
geebee9
worksheet register
Post by geebee9 »
i have been using plan maker for many years and suddenly none of my worksheets now show the worksheet register. it is not visible now and i don't know how to get it back. Is there an easy way to bring the register back?
g Ball
Re: worksheet register
Thank you for posting your problem, but we are unable to reproduce this problem.
Please update your FreeOffice and then check. If your FreeOffice is already updated, please reinstall it completely and then check.
This is a document property. File, Properties, Options, Sheet tabs
