Enlarge and reduce font size shortcut
sofian
Post by sofian »
hi
can you make the same shortcut for font size like in microsoft woord ?
in woord it is :
less size : ctrl + shift + <
more size : ctrl + shift + >
thanks
Re: Enlarge and reduce font size shortcut
That shortcut does not work in Word 2019
sofian
Post by sofian »
Woody44 wrote: Sun Mar 31, 2024 11:44 am That shortcut does not work in Word 2019
it works in all word versions .
i start use it from word 2013 to 2021 .
I have used every version of Word from 2003 though 2019. I am currently on Word 2019. I have never before heard of this shortcut and, upon reading your post, I immediately opened a document in Word and tried it.
It does not work. I just tried it again. Is it a macro you created?
sofian
Post by sofian »
Woody44 wrote: Sun Mar 31, 2024 8:16 pm I have used every version of Word from 2003 though 2019. I am currently on Word 2019. I have never before heard of this shortcut and, upon reading your post, I immediately opened a document in Word and tried it.
it is my fault, sorry
the shortcut in word is ctrl + shift + < and ctrl + shift + >
steps (in word) :
select a text .
use ctrl + shift + < and ctrl + shift + >
i hope it is clear now .
Yes, that works -- in Word. You are correct, it doesn't work in TextMaker (and it also doesn't work in LibreOffice Writer).
[Note: For those who may be confused, the original post showed the shortcut as ctrl+< and ctrl+>. After I reported that it didn't work, the OP edited it to ctrl+shft+< and ctrl+shft+>.]
sofian
Post by sofian »
Woody44 wrote: Sun Mar 31, 2024 11:41 pm Yes, that works -- in Word. You are correct, it doesn't work in TextMaker (and it also doesn't work in LibreOffice Writer).
Do you think this feature will be implemented in the program?
I cannot give up this feature after being accustomed to it for years.
thanks
Ctrl+8 and Ctrl+9
sofian
Post by sofian »
martin-k wrote: Mon Apr 01, 2024 10:24 am Ctrl+8 and Ctrl+9
amazing
yes , it is working .
thanks
