Cannot Save File To OneDrive
Re: Cannot Save File To OneDrive
Thank you for reporting this problem. Please share your sminfo.txt file, which you can generate by ribbon command File | Help '?' | About | Write system information.
Thank you for sharing sminfo.txt file, but there is some known problem in OneDrive as it corrupts the files while saving on it. That's why it will not work.
Please use some other cloud service provider or save your file on local storage.
ananclipping
Post by ananclipping »
densu wrote: Mon Mar 25, 2024 7:17 am Hello
I can opened file from OneDrive,but I can't save the file that I Opened it to OneDrive.
I had check "Use system file dialogs" in Option setting
Please answer my question.
It appears that OneDrive synchronization may not be functioning properly. You might try the following:
Verify OneDrive's status to make sure it is operational and synchronizing correctly. Locate the cloud icon on your taskbar and verify that there are no problems with syncing.
Verify the permissions of the file: Verify that the file is not in OneDrive's "View Only" mode. Check the permissions by doing a right-click on the file in OneDrive.
Save the file as a new one: To save the file, try using "Save As" and choosing a new place inside your OneDrive folder.
Reconnect OneDrive: To restart the connection, try unlinking and relinking your OneDrive account.
Try a Different App: Try saving the file from a different Office application, such as Word or Excel, if you're using Office applications.
Return to “PlanMaker NX for Android”
