Upon execution of update:
"no valid softmaker office 2024 in folder C:|programfiles\softmaker office 2024\. Error code 0."
(Yes, S.O. 2024 is installed / working in C:|programfiles\softmaker office 2024)
Update Issue
Re: Update Issue
Thank you for reporting this problem. Please download the full software package from here, run it and let us know the results.
This will resolve your update issue.
Re: Update Issue
The result is error message:
"This product key is for a different product...."
Re: Update Issue
After install.
It's showing PlanMaker Trial NX (rev S1210.0217) 64bit.
(Forced to run in Trial Mode)
- Contact:
Re: Update Issue
SuperTech gave you the wrong link. You need to install SoftMaker Office 2024 (since that's what you bought) and not SoftMaker Office NX.
https://www.softmaker.com/en/download/applications
