1211 Update Fails
Post here topics for SoftMaker Office NX and 2024 for Linux that do not fit in any of the application-specific subforums.
nberg3
1211 Update Fails
Post by nberg3 »
Trying to update on Opensuse Tumbleweed and the install fails:
error: %prein(softmaker-office-nx-nx-1211.x86_64) scriptlet failed, exit status 1
error: softmaker-office-nx-nx-1211.x86_64: install failed
error: softmaker-office-nx-nx-1210.x86_64: erase skipped
(1/1) Installing: softmaker-office-nx-nx-1211.x86_64 ..........................................................[error]
Installation of softmaker-office-nx-nx-1211.x86_64 failed:
Error: Subprocess failed. Error: RPM failed: Command exited with status 1.
Abort, retry, ignore? [a/r/i] (a): r
Please use -E option, e.g.
sudo -E rpm -i path_to_package
sudo -E zypper install softmaker...
Re: 1211 Update Fails
Which command did you enter for the installation?
lgsl
Post by lgsl »
Martin:
I have encounter this issue since a few versions back. Is rather annoying when one is doing a distro update (zypper dup). One should not have to use sudo zypper -E zypper for security reasons. Why is necessary to preserve environment variables when upgrading SMO? The package should be agnostic to the user environment variables. And this is not a new topic. I am referring to this thread. Seems to me that all of us using OpenSUSE Tumbleweed have been experiencing the same annoying error.
Nberg3:
For now upgrade using this command: sudo -E zypper up softmaker-office-nx
nberg3
Post by nberg3 »
Thank you I will try that
en_grehlinn
Post by en_grehlinn »
Had the same problem today and for tumbleweed users “ sudo -E zypper up softmaker-office-nx ” does the job for softmaker-office-nx-1214 as well.
Just in case someone has the problem today , too. Thank you for the advice.
Return to “SoftMaker Office NX and 2024 for Linux (General)”
