LONG FORMULAS IN A CELL BLOCKS MY SELECTION
adpd777
Post by adpd777 »
Hello.
I want to report an issue, here is the thing.
When I want to use a formula, in this case:
Code: Select all
=sum(cell1,cell2,cell3,etc)
I come into a point where I can't continue selecting more cells because the formula blocks my selection, I think this can be solved by making the formula move automatically while I select multiple cells or by making it disappear, but allowing me to continue selecting and checking the selection in the formula bar.
I took a screenshot and uploaded it to make it easier to understand my situation.
Thank you.
Re: LONG FORMULAS IN A CELL BLOCKS MY SELECTION
Thank you for reporting this problem with screenshot. I have forwarded the details...
Meanwhile, you can use keyboard arrow keys to select cells which you want to include and which are behind formula text.
adpd777
Post by adpd777 »
SuperTech wrote: Fri Mar 08, 2024 2:35 pm Thank you for reporting this problem with screenshot. I have forwarded the details...
Yes, that's exactly what I had to do.
Thank you.
Return to “FreeOffice PlanMaker 2021 for Linux”
