I could not install Office NX in Linux Archman. The error is shown below. How can I solve it?
tar xvzf ./softmaker-office-2021-1068-amd64.tgz
tar (child): ./softmaker-office-2021-1068-amd64.tgz: open olanaksız: Böyle bir dosya ya da dizin yok
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
I couldn't install office nx on linux archman.
acahan3500
- Contact:
Re: I couldn't install office nx on linux archman.
That's the wrong file name. You need to download https://www.softmaker.net/down/softmake ... -amd64.tgz and then install softmaker-office-nx-1208-amd64.tgz
acahan3500
Isn't this the link to download?
- Contact:
This is the same link I gave you.
acahan3500
user@ ~ % tar xvzf /home/user/İndirilenler/softmaker-office-nx-1208-amd64.tgz
officenx.tar.lzma
installofficenx
user@pcdestek.info.tr ~ % installofficenx
user@pcdestek.info.tr~ % zsh: command not found: installofficenx
officenx.tar.lzma
installofficenx
- Contact:
You need to follow the installation instructions at https://www.softmaker.com/en/support/in ... e-nx#other
The command is:
./installofficenx
and not:
installofficenx
The command is:
./installofficenx
and not:
installofficenx
acahan3500
It seems that you DON'T have root permissions!
If you have root permissions, you can install the application
for all users on this machine.
If you do not have root permissions or want SoftMaker Office NX
only to be used by the current user, you can install it locally.
Do you want to install SoftMaker Office NX only for the current user? (y/n) [y]
