[Feature request]Comments window
xahodo
Post by xahodo »
Hello,
I have a document where I might end up with loads of comments. I'm aware of the option to cycle through comments, but if you're thinking in the order of hundreds of comments, then pressing the previous/next comment buttons a million times (maybe skipping past the one you're looking for by accident), things get quite tedious.
How about a window that lists all comments in the text and text they're linked to? This would be really helpful for me. It would be even more helpful if you were able to then search through those comments, either through the linked text, or the comments themselves.
Things would be even better if regular expression support was included in that search. That search would be even better if it was also capable of search and replace.
Hope this feature request makes it into a next version of SM Office. :)
Re: [Feature request]Comments window
Thank you for your post. I have forwarded this improvement suggestion.
