Very slow document loading
ubergeek72@gmail.com
Post by ubergeek72@gmail.com »
Hi. I'm using TextMaker 2024 for Linux. It's been uniformly good except for one small issue.
I write novels, so I'm going to routinely throw documents between 50,000 words and 100,000 words at TextMaker, often with comments and tracked changes. These are stored in docx, as generated by other software. (I actually write in markdown. TextMaker is for when I have to share documents with others, like my editor.) Once the documents are loaded, response times seem fine, unlike LibreOffice Writer, but they do take quite a long time to load.
Here's the snippet from tmlog.txt, showing a document taking nearly 40 seconds to load, on a core i7 4790k from an ssd.
[ 11361ms][ 9985ms]: LoadDocument </home/jim/Dropbox/Poltergeist_Stories/p2-Dead_of_Winter/et-edits_Dead_Of_Winter-DOCX.baked.docx>
[ 11367ms][ 6ms]: ReadDocument </home/jim/Dropbox/Poltergeist_Stories/p2-Dead_of_Winter/et-edits_Dead_Of_Winter-DOCX.baked.docx>
[ 48428ms][ 37061ms]: ReadDocument End
This file is 457kib. I haven't seen word processor load times like this since the 1980s. There's nothing else in the log that pertains to the file load. It doesn't appear to be an openGL matter, since I get the same load times whether I have openGL and openGL autoshapes set or not.
Re: Very slow document loading
Thank you for reporting this issue. Are you facing this problem in this specific file or with other files also?
How's is your overall system performance, are you facing slow loading issue with other software also?
Overall system performance is pretty good. As an example, creating the docx file with pandoc from the markdown takes a few seconds. Interestingly, the new docx opens in TextMaker in a second or two. It must be the comments that are slowing things down. There are hundreds.
Thank you for the information. Please share any document in which you are facing this problem and tmlog.txt for that document so that we can investigate this problem.
File sent. I wanted to get the book in print before letting drafts of it out of my sight.
-JRS
Thank you for sharing the file, but the file opened fast. Please share your tmlog.txt file so that we can diagnose this issue.
Looks like this may have been a Linux only issue, or some weirdness with my Linux setup. As I have now switched to a mac, and the mac version of Textmaker, I can't test this usefully anymore. That file opens quickly on my mac.
