Backspace misbehavior
xahodo
Post by xahodo »
I'm typing quite a long piece of text, and occasionally I want to remove something and hold the backspace key. The result is that I get no visual feedback until I release the backspace key. This, more often than not, results in me deleting more than I want to.
Is there a way to fix this behavior?
Re: Backspace misbehavior
Is this happened once or every time you press and hold the backspace key?
xahodo
Post by xahodo »
I've discovered it occurs when my computer is underclocked. When I put the amount of GHz up (from 1.3 to 2.7) things were miraculously fixed.
This problem consistently happens when at 1.3GHz.
So, it seems, this is your computer related problem and not SoftMaker Office.
