Change softmaker path
stephan1827
Post by stephan1827 »
Hi,
I installed Softmaker on my Mac and it created a folder Softmaker under Documents. I would like to change that folder but can only find settings for sub folders but not the complete Softmaker folder.
Thx
Stephan
Re: Change softmaker path
Please let us know what you want to change in SoftMaker folder?
stephan1827
I would like to change the location of the whole folder SoftMaker from \Documents on level up.
Stephan
Thank you for reply, but it's not possible as this folder is required on this location for proper execution of the program.
stephan1827
I understand that this might be the way it is right now but since the Linux Users also complained about this limitation maybe there is a chance you could make this adjustable.
Stephan
I don't think so, but I have forwarded this improvement suggestion…
Return to “TextMaker NX and 2024 for Mac”
