Dictate text into Textmaker
greenleaves
voice to text dictation
Post by greenleaves »
Hi
I just downloaded the Windows version but there is no option to enable dictation. I particularly need it in Textmaker. Please can you add it, as otherwise I will uninstall the software
thank you
greenleaves
Hi
I saw on another post- for Mac- there seems to be a feature to enable dictation, but I don't see it for the Windows version (I just downloaded it). It's an essential feature for me, please add it
thank you
Re: Dictate text into Textmaker
Thank you for your post. In Windows, there is no need to enable it as it's already enabled on SoftMaker Office level.
If you have enabled it in Windows settings, Press Win+H to show it, click on Mic icon, click in TextMaker and start dictation and it will work. Please try and let us know the results.
