Removing the gray margin lines
PTR
Post by PTR »
Hi. How can i remove the margin lines? I use the standard view, but i dont need a constant reminder on the margins, i already know where they are but i cannot seem to find a way to remove it to have a more clean view of my document. Thank you very much.
Re: Removing the gray margin lines
Thank you for your post. To remove margin lines, please click on ribbon command File | Options | View tab | uncheck the option “Page margins” in document windows group | Click OK.
PTR
Post by PTR »
Very Good!!!
But how do i remove the gray box for the header and footer? Thank you very much.
stascheit
Post by stascheit »
Ribbon command File | Options | View tab | uncheck the option “Frame guidelines” (in the same section where you found the "Page margins" option).
PTR
Post by PTR »
It seems that for mac, that option is not enabled. Attaching the image for your reference. Am I looking into the correcto prompt?
stascheit wrote: Mon Jan 08, 2024 12:08 pm Ribbon command File | Options | View tab | uncheck the option “Frame guidelines” (in the same section where you found the "Page margins" option).
Actually, you are looking at the wrong dialogue box, please click on File | Options as mentioned above and shown in the below screenshot.
Return to “TextMaker NX and 2024 for Mac”
