Different header and footer on the first page
PTR
Post by PTR »
If i open a document modified on ms office that contains different header and footer it works fine, nevertheless if i create a new document, i dont seem to find a way to have a different footer and header for the first page. Can you please let me know if this is possible and how?
Re: Different header and footer on the first page
To treat first page differently, please click on ribbon command Layout | Chapter | Chapter tab | check the option “Different first page” | Click OK. Then you will be able to set different Header/footer etc. for the first page.
balstag
Post by balstag »
I do this, still I cannot have a different header on the the first page of the chapter. In a book there is no header on the first page of a chapter, but how can I do this in Textmaker? I'm a NX subscriber, and cannot use Textmaker if I cannot solve this. When I remove the text in the header of the first page of a chapter, all the others are changed as well -- even if I have chosen "different first page", what is the problem?
Thank you for following the steps provided. However, I am unable to reproduce the issue, as the steps seem to be working fine on my end.
Could you please share the document in which you're encountering the problem? This will help us investigate further and resolve the issue more effectively.
Return to “TextMaker NX and 2024 for Mac”
