Practical size limit for text file
caspar4
Post by caspar4 »
I'm running into issues opening and saving a file of 1.6 MB. Is that too large?
Does it make a difference whether it's .rtf or .tmdx ?
TM 2021 presented no problems with my files, whether .rtf or .tmdx. But TM2024 takes a long time to load a big file. Often program crashes when I try to save the file. The program with 3 files loaded uses 250 MB of RAM. Does that make sense?
I'm ready to go back to TM 2021 if I can't get this fixed.
Re: Practical size limit for text file
Thank you for posting your problem. Please share the file with which you are getting this problem so that we can check it at our end.
If this issue is with all the files, please execute the following command in command prompt and share tmlog.txt which you can find in Documents/SoftMaker folder.
Code: Select all
TextMaker -debug
