Does FreeOffice (textmaker) do macros?
Grouch
Post by Grouch »
Hi,
When I was looking for a free MS Office replacement suite, I looked for something that supports macros, and FreeOffice came up in the search results. But I don't see the ability to do that, nor any menu options that might indicate the possibility.
Am I just missing it, or do I need to continue my search for an office suite (and if so, any suggestions)?
Thanks very much.
Re: Does FreeOffice (textmaker) do macros?
No, FreeOffice don't have macros but our SoftMaker Office which is commercial software have BasicMaker module, using which you can create VBA macro like scripts.
You can try it for 30 days for free and after that you can subscribe/purchase it.
