Customize the context menu.
Starman
Post by Starman »
Sorry if this has asked/answered already, but I searched and could not find it. Is it possible to customize the right-click dropdown context menu, such as being able to add the "Fill" command? (To be clear, I am referring to the menu that appears on a right click after you have selected some cells.) I use that command often and it would be very convenient to have it on that menu. I know how to customize the other menus, but find no option for the context menu. Thanks.
Re: Customize the context menu.
Thank you for your post. Currently, customize the context menu is not possible, but I have forwarded the improvement suggestion.
